THS4011 SPICE model - Версия для печати +- Audio Perfection Forum (https://www.audio-perfection.com/forum) +-- Форум Моделирование. SPICE. LTSPICE (https://www.audio-perfection.com/forum/forumdisplay.php?fid=5) +--- Форум Модели элементов в SPICE формате, библиотеки элементов (https://www.audio-perfection.com/forum/forumdisplay.php?fid=6) +--- Темы: THS4011 SPICE model (/showthread.php?tid=510) |
THS4011 SPICE model - nazar - 04-21-2017 * The following parameters are modeled: * 1. Open loop gain and phase with RL and CL effects * 2. AC/DC Common mode rejection ratio * 3. AC/DC Power supply rejection ratio * 4. Slew rate * 5. Input voltage noise with 1/f * 6. Input curent noise with 1/f * 7. Input bias current with common mode * 8. Input offset current * 9. Input offset voltage with temperature effects * 10. Input impedance * 11. Output current through the supply rails * 12. Output current limit * 13. Output voltage swing from rails with RL effects * 14. Output impedance * 15. Quiescent current vs Supply voltage with temperature effects * 16. Maximum supply voltage breakdown * 17. Overload recovery / No phase reversal * 18. Input common mode voltage range http://s-audio.systems/blog/spicemodels/ RE: THS4011 SPICE model - nazar - 12-12-2018 Поправил модель согласно измеренных данных |
