BassCADe 3.4.4.0 -
EDWARD - 01-02-2019
BassCADe 3.4.4.0
http://www.selfmadehifi.de
The following is possible in BassCADe:
A speaker data search depending on different TSP values, names etc...
delivered will be more than 4000 speaker data sets (subwoofer, woofer, midbass)
Advices for bass box types depending on Thiele-Small-Parameters of the speaker
Calculation and simulation of open (bi-pole), contained, reflex boxes, additional sealed an vented ban pass types
comparision of box simulations up to 6 curves (also with abolute levels and different power)
calculation of expo-horns
caclulation of TML (transmissionline) housings
Calculation and re-calc of reflex tubes and tunnel dimensions
Calculation of outer dimensions of box housings depending on inner volume and board thicknesses (cuboid, car-sub, cylinder and pyramide form)
Calculation and simulation of passive filter networks for speaker crossovers: low-pass, band-pass, high-pass up to 4th order
total X-over simulation
Calculation of impedance linearisation for passive filters
Calculation of level correction with device-power estimation depending on different frequency spectrums (can also be defined by yourself)
Calculation of air coil dimensions to get a wanted inductivity
Calculation of maximum sound pressure level (up to 3 different types at the same time) depending on SPL, power and distances
Find the TSPs depending on measurement values
Calculation of occupation (speaker displacement) volume depending on speaker dimensions
Calculation of the loss factor QL of vented housings depending on measured values
Unit-calculater for length, surface, volume, level (dB), wire diameter and lineary interpolation
Total impedance calculation of speaker networks in many combinations up to 50 speakers
Loss-calculation of speaker cables
Dimensioning of Car-HiFi power supply cabeling (up to 4 amps)
DOWNLOAD: BassCADe 3.4.4.0 (german / english) for Windows 32-Bit
Server 1 download/basscad.exe (relativ)
http://www.selfmadehifi.de/download/basscad.exe
file://www.selfmadehifi.de/download/basscad.exe download/basscad.zip
http://www.selfmadehifi.de/download/basscad.zip
file://www.selfmadehifi.de/download/basscad.zip
http://www.selfmadehifi.de/download/TSP.ZIP
