Altor Audio Написал:Вообще-то да - или на самом ЦАПе, или на блоке питания (или входа с них на плату).речь идёт о WM8741, для него только один вариант. Мде...
Some devices are sensitive to “delta ground” and some are sensitive to “delta supply”. For these cases, it is important to maintain equal potentials at the respective pins. For example, a “delta ground” device requires that all ground pins (analog and digital) have a potential of less than 300mV between them. For a delta ground device, it is recommended that all of the ground pins be tied to the same plane, typically the analog ground plane.
