DAC <<5V>> wm8741
wired Написал:ну от такое вьішло
The Vref pin on an ADC/DAC is one of the most critical nodes in a circuit, and is often over looked. Internally, this pin is normally used to supply charge to a Switch capacitor network (in a 1 Bit or Low Bit DAC). The charge is drawn at the internal switching rate – but with an Audio modulation component. Therefore, this Node needs to be well de-coupled at both the Audio Band and “RF” frequencies.
If you where to perform an Impendence plot of any capacitor, you will see a wildly varying curve, with the De-Coupling properties of the capacitor rapidly reducing at LF. This increasing impendence at LF has a large impact on Bass quality – resulting in “1 Bit or Low Bit” DAC’s sounding “light” in the Bass.
The RF quality of the 100nF ceramic is critical, try placing it directly across the DAC Vref Pin and Ground
With the external VGen circuit, Bass becomes very tight – controlled with no “Bloom” and the sound stage opens up!
With the Vref pin - noise is not the only important issue – the foremost reason for using the external VGen circuit is to reduce the VREF impedance across the entire audio band including LF.
DAC <<5V>> wm8741 - от wired - 02-14-2016, 05:58 AM
RE: DAC <<5V>> wm8741 - от EDWARD - 02-16-2016, 04:07 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-16-2016, 04:22 PM
RE: DAC <<5V>> wm8741 - от EDWARD - 02-16-2016, 04:28 PM
RE: DAC <<5V>> wm8741 - от wired - 02-16-2016, 04:29 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-16-2016, 04:36 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-16-2016, 06:35 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-16-2016, 08:27 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-16-2016, 09:26 PM
RE: DAC <<5V>> wm8741 - от Altor Audio - 02-16-2016, 11:14 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 12:04 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-17-2016, 12:45 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 12:49 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-17-2016, 12:56 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 12:59 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-17-2016, 01:03 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-17-2016, 01:16 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 01:18 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-17-2016, 01:26 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 01:26 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 01:29 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 01:40 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 01:41 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 01:50 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 01:52 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 01:55 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 01:57 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 02-17-2016, 02:07 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 02:17 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 02:27 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 02:28 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-17-2016, 03:06 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 03:08 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 03:40 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 04:34 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 05:59 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 06:29 AM
RE: DAC <<5V>> wm8741 - от EDWARD - 02-17-2016, 07:34 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 08:14 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 08:49 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 08:55 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 09:00 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 09:26 AM
RE: DAC <<5V>> wm8741 - от wired - 02-17-2016, 09:56 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 10:01 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 10:14 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-17-2016, 04:55 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-17-2016, 05:57 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-17-2016, 08:34 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-18-2016, 12:29 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-18-2016, 12:35 AM
RE: DAC <<5V>> wm8741 - от wired - 02-18-2016, 04:57 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-18-2016, 02:12 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-18-2016, 02:20 PM
RE: DAC <<5V>> wm8741 - от s3t - 02-18-2016, 02:26 PM
RE: DAC <<5V>> wm8741 - от wired - 02-18-2016, 02:47 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-18-2016, 02:49 PM
RE: DAC <<5V>> wm8741 - от wired - 02-18-2016, 02:59 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-18-2016, 08:10 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-18-2016, 08:34 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-19-2016, 12:11 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-19-2016, 12:38 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-19-2016, 01:06 AM
RE: DAC <<5V>> wm8741 - от wired - 02-19-2016, 01:15 AM
RE: DAC <<5V>> wm8741 - от wired - 02-19-2016, 02:16 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-19-2016, 04:23 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-19-2016, 05:02 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-19-2016, 05:28 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-19-2016, 05:56 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-19-2016, 06:17 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-19-2016, 09:18 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-19-2016, 09:31 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-19-2016, 09:45 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-19-2016, 09:56 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-19-2016, 11:28 AM
RE: DAC <<5V>> wm8741 - от shkal - 02-19-2016, 12:45 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-19-2016, 01:59 PM
RE: DAC <<5V>> wm8741 - от begemot - 02-19-2016, 04:26 PM
dac 5v - от wired - 02-19-2016, 11:14 PM
RE: DAC <<5V>> wm8741 - от begemot - 02-20-2016, 01:13 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 02-20-2016, 02:29 AM
RE: DAC <<5V>> wm8741 - от wired - 02-20-2016, 04:05 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-20-2016, 04:08 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-20-2016, 05:46 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-20-2016, 06:29 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-20-2016, 06:50 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-20-2016, 06:55 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 02-20-2016, 07:01 AM
RE: DAC <<5V>> wm8741 - от s3t - 02-20-2016, 07:48 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-20-2016, 07:50 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-20-2016, 08:53 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-20-2016, 01:12 PM
RE: DAC <<5V>> wm8741 - от wired - 02-20-2016, 02:06 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-20-2016, 06:10 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-20-2016, 06:44 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-20-2016, 06:46 PM
RE: DAC <<5V>> wm8741 - от begemot - 02-20-2016, 08:55 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-20-2016, 09:16 PM
RE: DAC <<5V>> wm8741 - от begemot - 02-20-2016, 10:20 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-21-2016, 03:16 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-21-2016, 03:31 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-21-2016, 04:15 AM
RE: DAC <<5V>> wm8741 - от wired - 02-21-2016, 04:21 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-21-2016, 04:46 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-21-2016, 05:17 AM
RE: DAC <<5V>> wm8741 - от bobby_ii - 02-21-2016, 05:25 AM
RE: DAC <<5V>> wm8741 - от s3t - 02-21-2016, 05:33 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-22-2016, 12:26 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 12:29 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-22-2016, 12:32 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 12:35 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-22-2016, 12:45 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-22-2016, 12:47 AM
RE: DAC <<5V>> wm8741 - от wired - 02-22-2016, 01:05 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-22-2016, 01:34 AM
RE: DAC <<5V>> wm8741 - от wired - 02-22-2016, 01:59 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-22-2016, 02:25 AM
RE: DAC <<5V>> wm8741 - от wired - 02-22-2016, 02:34 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-22-2016, 02:44 AM
RE: DAC <<5V>> wm8741 - от wired - 02-22-2016, 02:49 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-22-2016, 03:44 AM
RE: DAC <<5V>> wm8741 - от wired - 02-22-2016, 04:06 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 04:12 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-22-2016, 04:23 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 04:26 AM
RE: DAC <<5V>> wm8741 - от wired - 02-22-2016, 09:42 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 10:24 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-22-2016, 11:52 AM
RE: DAC <<5V>> wm8741 - от wired - 02-22-2016, 12:10 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 12:14 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 12:16 PM
RE: DAC <<5V>> wm8741 - от begemot - 02-22-2016, 12:18 PM
RE: DAC <<5V>> wm8741 - от nazar - 02-22-2016, 12:39 PM
RE: DAC <<5V>> wm8741 - от wired - 02-22-2016, 03:19 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 07:52 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-22-2016, 10:31 PM
RE: DAC <<5V>> wm8741 - от begemot - 02-22-2016, 11:49 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-23-2016, 03:27 AM
RE: DAC <<5V>> wm8741 - от wired - 02-23-2016, 04:58 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-23-2016, 05:00 AM
RE: DAC <<5V>> wm8741 - от wired - 02-23-2016, 05:42 AM
RE: DAC <<5V>> wm8741 - от wired - 02-23-2016, 06:06 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-23-2016, 06:26 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-23-2016, 06:27 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-23-2016, 06:56 AM
RE: DAC <<5V>> wm8741 - от wired - 02-23-2016, 07:05 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-23-2016, 07:38 AM
RE: DAC <<5V>> wm8741 - от wired - 02-23-2016, 07:49 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-23-2016, 07:53 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-23-2016, 08:16 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-23-2016, 08:24 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-23-2016, 08:25 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-23-2016, 08:27 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-23-2016, 08:41 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-23-2016, 08:43 AM
RE: DAC <<5V>> wm8741 - от nazar - 02-23-2016, 08:50 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-23-2016, 08:53 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-23-2016, 09:06 AM
RE: DAC <<5V>> wm8741 - от wired - 02-23-2016, 09:19 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-23-2016, 11:54 AM
RE: DAC <<5V>> wm8741 - от wired - 02-23-2016, 12:10 PM
RE: DAC <<5V>> wm8741 - от begemot - 02-23-2016, 12:14 PM
RE: DAC <<5V>> wm8741 - от wired - 02-23-2016, 12:28 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-23-2016, 06:17 PM
RE: DAC <<5V>> wm8741 - от begemot - 02-23-2016, 06:19 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-23-2016, 06:46 PM
RE: DAC <<5V>> wm8741 - от wired - 02-27-2016, 04:05 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-27-2016, 04:16 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-27-2016, 07:36 PM
RE: DAC <<5V>> wm8741 - от wired - 02-27-2016, 11:55 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 02-27-2016, 11:58 PM
RE: DAC <<5V>> wm8741 - от wired - 02-28-2016, 12:11 AM
RE: DAC <<5V>> wm8741 - от wired - 02-29-2016, 06:56 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-29-2016, 07:10 AM
RE: DAC <<5V>> wm8741 - от wired - 02-29-2016, 07:16 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-29-2016, 07:17 AM
RE: DAC <<5V>> wm8741 - от begemot - 02-29-2016, 08:46 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-29-2016, 09:18 AM
RE: DAC <<5V>> wm8741 - от wired - 02-29-2016, 09:37 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 02-29-2016, 08:59 PM
RE: DAC <<5V>> wm8741 - от wired - 02-29-2016, 11:45 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 03-01-2016, 12:07 AM
RE: DAC <<5V>> wm8741 - от wired - 06-24-2016, 02:56 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 06-24-2016, 05:01 AM
RE: DAC <<5V>> wm8741 - от wired - 06-24-2016, 05:13 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 06-24-2016, 05:37 AM
RE: DAC <<5V>> wm8741 - от wired - 06-24-2016, 10:16 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 06-24-2016, 06:44 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 06-26-2016, 01:11 AM
RE: DAC <<5V>> wm8741 - от wired - 06-26-2016, 01:17 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-12-2016, 08:40 AM
RE: DAC <<5V>> wm8741 - от wired - 07-12-2016, 10:42 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-12-2016, 10:45 AM
RE: DAC <<5V>> wm8741 - от wired - 07-12-2016, 10:57 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-12-2016, 02:00 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-12-2016, 02:06 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-12-2016, 05:05 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-12-2016, 10:48 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-12-2016, 10:50 PM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-13-2016, 12:07 AM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-13-2016, 01:24 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-13-2016, 01:48 AM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-13-2016, 01:55 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-13-2016, 05:09 AM
RE: DAC <<5V>> wm8741 - от s3t - 07-13-2016, 06:32 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-13-2016, 06:37 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-13-2016, 06:46 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-13-2016, 06:50 AM
RE: DAC <<5V>> wm8741 - от s3t - 07-13-2016, 07:11 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-13-2016, 07:44 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-13-2016, 07:46 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-13-2016, 07:49 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-13-2016, 07:51 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-13-2016, 08:01 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-13-2016, 10:12 AM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-13-2016, 10:32 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-13-2016, 01:01 PM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-13-2016, 01:44 PM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-13-2016, 01:47 PM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-13-2016, 02:03 PM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-13-2016, 02:25 PM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-13-2016, 02:46 PM
RE: DAC <<5V>> wm8741 - от MikeF - 07-13-2016, 06:50 PM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-13-2016, 08:28 PM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-14-2016, 12:21 AM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-14-2016, 12:52 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-14-2016, 02:47 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-14-2016, 03:43 AM
RE: DAC <<5V>> wm8741 - от wired - 07-14-2016, 10:46 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-15-2016, 07:21 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-15-2016, 07:40 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-15-2016, 07:42 AM
RE: DAC <<5V>> wm8741 - от s3t - 07-15-2016, 07:47 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-15-2016, 07:57 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-15-2016, 09:09 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-15-2016, 11:34 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-15-2016, 11:37 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-15-2016, 06:25 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-15-2016, 08:11 PM
RE: DAC <<5V>> wm8741 - от begemot - 07-15-2016, 10:01 PM
RE: DAC <<5V>> wm8741 - от wired - 07-15-2016, 10:55 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-16-2016, 12:54 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-16-2016, 02:11 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-16-2016, 07:24 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-16-2016, 07:26 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-16-2016, 07:32 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-16-2016, 07:49 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-16-2016, 07:55 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-16-2016, 07:59 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-16-2016, 08:05 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-16-2016, 08:18 AM
RE: DAC <<5V>> wm8741 - от s3t - 07-16-2016, 08:26 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-16-2016, 08:27 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-16-2016, 09:28 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-16-2016, 09:33 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-16-2016, 10:38 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-17-2016, 12:57 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-17-2016, 11:16 PM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-18-2016, 01:43 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-18-2016, 05:50 PM
RE: DAC <<5V>> wm8741 - от wired - 07-22-2016, 02:04 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-22-2016, 03:36 AM
RE: DAC <<5V>> wm8741 - от wired - 07-22-2016, 05:34 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-22-2016, 05:39 AM
RE: DAC <<5V>> wm8741 - от wired - 07-22-2016, 05:46 AM
RE: DAC <<5V>> wm8741 - от wired - 07-22-2016, 06:03 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-22-2016, 06:44 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-22-2016, 07:11 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-22-2016, 07:49 AM
RE: DAC <<5V>> wm8741 - от EDWARD - 07-22-2016, 08:03 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-22-2016, 08:06 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-22-2016, 08:07 AM
RE: DAC <<5V>> wm8741 - от MikeF - 07-22-2016, 08:34 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-22-2016, 08:56 AM
RE: DAC <<5V>> wm8741 - от MikeF - 07-22-2016, 09:07 AM
RE: DAC <<5V>> wm8741 - от bobby_ii - 07-22-2016, 09:09 AM
RE: DAC <<5V>> wm8741 - от wired - 07-22-2016, 04:02 PM
RE: DAC <<5V>> wm8741 - от s3t - 07-22-2016, 05:38 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-22-2016, 07:27 PM
RE: DAC <<5V>> wm8741 - от wired - 07-22-2016, 10:44 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-23-2016, 01:06 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-23-2016, 04:28 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-23-2016, 04:37 AM
RE: DAC <<5V>> wm8741 - от wired - 07-23-2016, 05:00 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-23-2016, 05:54 AM
RE: DAC <<5V>> wm8741 - от wired - 07-23-2016, 06:00 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-23-2016, 06:20 AM
RE: DAC <<5V>> wm8741 - от wired - 07-23-2016, 04:14 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-23-2016, 05:06 PM
RE: DAC <<5V>> wm8741 - от begemot - 07-23-2016, 05:48 PM
RE: DAC <<5V>> wm8741 - от begemot - 07-23-2016, 05:57 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-23-2016, 07:08 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-23-2016, 07:23 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-23-2016, 07:27 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-23-2016, 07:37 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-23-2016, 07:43 PM
RE: DAC <<5V>> wm8741 - от begemot - 07-23-2016, 07:53 PM
RE: DAC <<5V>> wm8741 - от EDWARD - 07-23-2016, 07:53 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-23-2016, 08:27 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-23-2016, 08:30 PM
RE: DAC <<5V>> wm8741 - от wired - 07-23-2016, 11:43 PM
RE: DAC <<5V>> wm8741 - от wired - 07-23-2016, 11:49 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-23-2016, 11:55 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-24-2016, 01:27 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-24-2016, 01:42 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-24-2016, 06:30 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-25-2016, 11:15 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-25-2016, 11:19 AM
RE: DAC <<5V>> wm8741 - от MikeF - 07-25-2016, 11:20 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-25-2016, 11:22 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-25-2016, 11:27 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-25-2016, 11:30 AM
RE: DAC <<5V>> wm8741 - от begemot - 07-25-2016, 12:12 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-25-2016, 12:14 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-25-2016, 12:20 PM
RE: DAC <<5V>> wm8741 - от begemot - 07-25-2016, 12:27 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-25-2016, 12:35 PM
RE: DAC <<5V>> wm8741 - от begemot - 07-25-2016, 12:42 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-25-2016, 12:56 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-25-2016, 01:04 PM
RE: DAC <<5V>> wm8741 - от begemot - 07-25-2016, 01:25 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-25-2016, 02:35 PM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 07-25-2016, 09:20 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-25-2016, 09:23 PM
RE: DAC <<5V>> wm8741 - от begemot - 07-25-2016, 10:09 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-25-2016, 11:11 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-25-2016, 11:23 PM
RE: DAC <<5V>> wm8741 - от wired - 07-26-2016, 12:32 AM
RE: DAC <<5V>> wm8741 - от antiluser - 07-26-2016, 02:02 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 07-26-2016, 02:41 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-26-2016, 04:50 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-26-2016, 07:46 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-30-2016, 09:49 PM
RE: DAC <<5V>> wm8741 - от wired - 07-31-2016, 12:53 AM
RE: DAC <<5V>> wm8741 - от wired - 07-31-2016, 03:21 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-31-2016, 03:25 AM
RE: DAC <<5V>> wm8741 - от wired - 07-31-2016, 03:27 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-31-2016, 03:46 AM
RE: DAC <<5V>> wm8741 - от wired - 07-31-2016, 03:52 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 07-31-2016, 04:21 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-31-2016, 01:54 PM
RE: DAC <<5V>> wm8741 - от wired - 07-31-2016, 01:56 PM
RE: DAC <<5V>> wm8741 - от wired - 07-31-2016, 02:16 PM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-31-2016, 11:27 PM
RE: DAC <<5V>> wm8741 - от wired - 08-01-2016, 12:21 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-01-2016, 12:41 AM
RE: DAC <<5V>> wm8741 - от wired - 08-05-2016, 02:35 AM
RE: DAC <<5V>> wm8741 - от nazar - 08-05-2016, 02:44 AM
RE: DAC <<5V>> wm8741 - от wired - 08-05-2016, 02:56 AM
RE: DAC <<5V>> wm8741 - от wired - 08-05-2016, 03:05 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-05-2016, 03:25 AM
RE: DAC <<5V>> wm8741 - от wired - 08-05-2016, 03:30 AM
RE: DAC <<5V>> wm8741 - от nazar - 08-05-2016, 03:33 AM
RE: DAC <<5V>> wm8741 - от wired - 08-05-2016, 03:43 AM
RE: DAC <<5V>> wm8741 - от nazar - 08-05-2016, 04:05 AM
RE: DAC <<5V>> wm8741 - от wired - 08-05-2016, 04:47 AM
RE: DAC <<5V>> wm8741 - от wired - 08-07-2016, 03:35 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-07-2016, 07:00 PM
RE: DAC <<5V>> wm8741 - от MikeF - 08-07-2016, 07:09 PM
RE: DAC <<5V>> wm8741 - от wired - 08-07-2016, 09:31 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-07-2016, 10:25 PM
RE: DAC <<5V>> wm8741 - от wired - 08-08-2016, 12:09 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-08-2016, 12:11 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-08-2016, 12:12 AM
RE: DAC <<5V>> wm8741 - от wired - 08-08-2016, 12:13 AM
RE: DAC <<5V>> wm8741 - от nazar - 08-08-2016, 03:40 AM
RE: DAC <<5V>> wm8741 - от wired - 08-08-2016, 03:45 AM
RE: DAC <<5V>> wm8741 - от nazar - 08-08-2016, 03:47 AM
RE: DAC <<5V>> wm8741 - от wired - 08-08-2016, 03:49 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-08-2016, 03:58 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-08-2016, 03:59 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-08-2016, 04:08 AM
RE: DAC <<5V>> wm8741 - от wired - 08-08-2016, 04:22 AM
RE: DAC <<5V>> wm8741 - от wired - 08-08-2016, 01:47 PM
RE: DAC <<5V>> wm8741 - от wired - 08-09-2016, 03:24 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-09-2016, 03:53 AM
RE: DAC <<5V>> wm8741 - от wired - 08-09-2016, 05:15 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-09-2016, 05:36 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-09-2016, 08:46 AM
RE: DAC <<5V>> wm8741 - от begemot - 08-09-2016, 05:42 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-09-2016, 11:39 PM
RE: DAC <<5V>> wm8741 - от wired - 08-10-2016, 12:10 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 01:51 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-10-2016, 02:13 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 02:44 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-10-2016, 02:48 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 03:14 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-10-2016, 03:17 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 03:22 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-10-2016, 03:40 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 04:15 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-10-2016, 04:35 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-10-2016, 04:48 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 04:56 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-10-2016, 05:01 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 05:41 AM
RE: DAC <<5V>> wm8741 - от wired - 08-10-2016, 05:46 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 06:08 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-10-2016, 06:53 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-11-2016, 06:58 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 08-11-2016, 07:43 AM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-11-2016, 07:46 AM
RE: DAC <<5V>> wm8741 - от aleksandrmiki - 08-30-2016, 12:10 PM
RE: DAC <<5V>> wm8741 - от nazar - 08-30-2016, 12:28 PM
RE: DAC <<5V>> wm8741 - от wired - 08-30-2016, 01:42 PM
RE: DAC <<5V>> wm8741 - от Altor Audio - 08-30-2016, 03:09 PM
RE: DAC <<5V>> wm8741 - от naroznyv - 08-30-2016, 07:26 PM
RE: DAC <<5V>> wm8741 - от wired - 10-02-2016, 08:05 AM
RE: DAC <<5V>> wm8741 - от nazar - 10-02-2016, 08:21 AM
RE: DAC <<5V>> wm8741 - от wired - 10-02-2016, 08:30 AM
RE: DAC <<5V>> wm8741 - от nazar - 10-02-2016, 09:18 AM
RE: DAC <<5V>> wm8741 - от wired - 10-02-2016, 09:56 AM
RE: DAC <<5V>> wm8741 - от nazar - 10-02-2016, 10:25 AM
RE: DAC <<5V>> wm8741 - от begemot - 10-02-2016, 11:25 AM
RE: DAC <<5V>> wm8741 - от wired - 10-02-2016, 11:26 AM
RE: DAC <<5V>> wm8741 - от wired - 10-02-2016, 11:55 AM
RE: DAC <<5V>> wm8741 - от sanny - 06-28-2017, 08:43 AM
RE: DAC <<5V>> wm8741 - от wired - 06-28-2017, 08:52 AM
RE: DAC <<5V>> wm8741 - от sanny - 06-29-2017, 12:56 AM
RE: DAC <<5V>> wm8741 - от wired - 06-29-2017, 01:39 AM
RE: DAC <<5V>> wm8741 - от sanny - 06-29-2017, 02:06 AM
RE: DAC <<5V>> wm8741 - от s3t - 06-29-2017, 02:29 AM
RE: DAC <<5V>> wm8741 - от nazar - 06-29-2017, 03:26 AM
RE: DAC <<5V>> wm8741 - от sanny - 06-29-2017, 03:29 AM
RE: DAC <<5V>> wm8741 - от nazar - 06-29-2017, 04:17 AM
RE: DAC <<5V>> wm8741 - от sanny - 06-29-2017, 05:00 AM
RE: DAC <<5V>> wm8741 - от nazar - 06-29-2017, 05:18 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 06-29-2017, 08:36 AM
RE: DAC <<5V>> wm8741 - от nazar - 06-29-2017, 09:15 AM
RE: DAC <<5V>> wm8741 - от s3t - 06-29-2017, 09:46 AM
RE: DAC <<5V>> wm8741 - от Altor Audio - 06-29-2017, 03:10 PM
RE: DAC <<5V>> wm8741 - от s3t - 06-29-2017, 03:37 PM
RE: DAC <<5V>> wm8741 - от sanny - 07-02-2017, 10:16 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-02-2017, 11:26 AM
RE: DAC <<5V>> wm8741 - от БендеровецЪ - 07-02-2017, 06:03 PM
RE: DAC <<5V>> wm8741 - от nazar - 07-03-2017, 03:31 AM
RE: DAC <<5V>> wm8741 - от sanny - 07-03-2017, 05:21 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-03-2017, 05:24 AM
RE: DAC <<5V>> wm8741 - от sanny - 07-03-2017, 06:14 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-03-2017, 06:47 AM
RE: DAC <<5V>> wm8741 - от sanny - 07-03-2017, 10:05 AM
RE: DAC <<5V>> wm8741 - от nazar - 07-03-2017, 10:18 AM
RE: DAC <<5V>> wm8741 - от sanny - 07-03-2017, 10:34 AM
RE: DAC <<5V>> wm8741 - от 81bas - 03-18-2018, 04:39 AM
RE: DAC <<5V>> wm8741 - от wired - 03-18-2018, 09:35 AM
RE: DAC <<5V>> wm8741 - от VitalikD - 04-05-2018, 10:30 AM
RE: DAC <<5V>> wm8741 - от wired - 04-05-2018, 11:28 AM
RE: DAC <<5V>> wm8741 - от sanny - 11-08-2018, 04:13 PM
RE: DAC <<5V>> wm8741 - от nazar - 11-09-2018, 03:56 PM
RE: DAC <<5V>> wm8741 - от sanny - 11-10-2018, 02:32 AM
RE: DAC <<5V>> wm8741 - от nazar - 11-10-2018, 03:58 AM
RE: DAC <<5V>> wm8741 - от EDWARD - 11-10-2018, 08:24 AM
RE: DAC <<5V>> wm8741 - от sanny - 11-11-2018, 02:13 PM
RE: DAC <<5V>> wm8741 - от sanny - 11-19-2018, 03:02 AM
RE: DAC <<5V>> wm8741 - от Pest - 01-17-2019, 08:47 PM
RE: DAC <<5V>> wm8741 - от nazar - 01-18-2019, 03:06 AM
RE: DAC <<5V>> wm8741 - от sanny - 07-24-2019, 07:43 AM
RE: DAC <<5V>> wm8741 - от wired - 07-24-2019, 02:51 PM
RE: DAC <<5V>> wm8741 - от sanny - 07-24-2019, 11:46 PM
RE: DAC <<5V>> wm8741 - от sanny - 07-26-2019, 12:05 AM
RE: DAC <<5V>> wm8741 - от Black_Jack - 07-26-2019, 01:12 AM
RE: DAC <<5V>> wm8741 - от sanny - 08-16-2019, 07:16 AM
RE: DAC <<5V>> wm8741 - от sanny - 08-27-2019, 09:05 AM
RE: DAC <<5V>> wm8741 - от sanny - 09-05-2019, 01:06 PM
RE: DAC <<5V>> wm8741 - от EDWARD - 09-07-2019, 04:23 AM
RE: DAC <<5V>> wm8741 - от wired - 09-07-2019, 07:33 AM
RE: DAC <<5V>> wm8741 - от sanny - 09-08-2019, 03:47 AM
RE: DAC <<5V>> wm8741 - от EDWARD - 09-08-2019, 05:04 PM
RE: UPLOAD - от naroznyv - 02-14-2016, 07:48 AM
RE: UPLOAD - от БендеровецЪ - 02-14-2016, 11:52 PM
RE: UPLOAD - от БендеровецЪ - 02-15-2016, 03:22 AM
RE: UPLOAD - от wired - 02-15-2016, 03:30 AM
RE: UPLOAD - от nazar - 02-15-2016, 03:43 AM
RE: UPLOAD - от БендеровецЪ - 02-15-2016, 03:46 AM
RE: UPLOAD - от nazar - 02-15-2016, 04:06 AM
RE: UPLOAD - от БендеровецЪ - 02-15-2016, 04:16 AM
RE: UPLOAD - от БендеровецЪ - 02-15-2016, 04:50 AM
RE: UPLOAD - от nazar - 02-15-2016, 09:11 AM
RE: UPLOAD - от naroznyv - 02-15-2016, 01:30 PM
RE: UPLOAD - от nazar - 02-15-2016, 01:56 PM
RE: UPLOAD - от БендеровецЪ - 02-15-2016, 05:05 PM
RE: UPLOAD - от nazar - 02-15-2016, 05:33 PM
RE: UPLOAD - от БендеровецЪ - 02-15-2016, 05:40 PM
RE: UPLOAD - от nazar - 02-15-2016, 06:14 PM
RE: UPLOAD - от БендеровецЪ - 02-15-2016, 06:21 PM
RE: UPLOAD - от nazar - 02-15-2016, 06:36 PM
RE: UPLOAD - от БендеровецЪ - 02-15-2016, 06:40 PM
RE: UPLOAD - от naroznyv - 02-15-2016, 08:55 PM
RE: UPLOAD - от БендеровецЪ - 02-16-2016, 02:37 AM
RE: UPLOAD - от wired - 02-16-2016, 02:51 AM
RE: UPLOAD - от naroznyv - 02-16-2016, 02:55 AM
RE: UPLOAD - от БендеровецЪ - 02-16-2016, 03:07 AM
RE: UPLOAD - от wired - 02-16-2016, 03:08 AM
RE: UPLOAD - от БендеровецЪ - 02-16-2016, 03:18 AM
RE: UPLOAD - от nazar - 02-16-2016, 03:38 AM
RE: UPLOAD - от wired - 02-16-2016, 04:03 AM
  DAC 7 wired 9 4,869 09-01-2020, 11:20 AM
Последний пост: wired
  8 канальный DAC Frap 3 3,147 11-21-2017, 05:19 PM
Последний пост: Black_Jack
  Внешний USB DAC shkal 26 18,973 06-27-2017, 08:37 AM
Последний пост: pautinqch
