LM6171 / LM6172 / LM7171 SPICE model
Сделал вчера модельки для LM6171 / LM6172 / LM7171 по скудным данным даташита и статьи Фархуда. Сделал потому что модельки ОУ от производителей это в основном весьма печальное зрелище.
Также в архиве пару тестбенчей для проверки параметров.
Модель предназначена для любых PSPICE based симуляторов.
The following parameters are modeled:
1. Open loop gain and phase with RL, CL effects and temperature effects
2. AC/DC Common mode rejection ratio
3. AC/DC Power supply rejection ratio
4. Slew rate
5. Input voltage noise with 1/f
6. Input curent noise with 1/f
7. Input bias current with common mode and temperature effects
8. Input offset current with temperature effects
9. Input offset voltage with temperature effects
10. Input impedance
11. Output current through the supply rails
12. Output current limit with temperature effects
13. Output voltage swing from rails with RL effects
14. Output impedance
15. Quiescent current vs Supply voltage with temperature effects
16. Maximum supply voltage breakdown
17. Overload recovery / No phase reversal
http://s-audio.systems/blog/spicemodels/
.zip   LM7171bench.zip (Размер: 9.3 KB / Загрузок: 60)
.zip   LM6171bench.zip (Размер: 9.11 KB / Загрузок: 61)
The following 8 users say Thank You to nazar for this post:
  • EDWARD (04-08-2017), naroznyv (04-10-2017), BesPav (04-16-2017), Abadakus (04-12-2018), Tuvalu (08-24-2018), mellowman (11-30-2018), Black_Jack (05-06-2019), БендеровецЪ (10-28-2019)
LM6171 / LM6172 / LM7171 SPICE model - от nazar - 04-08-2017, 04:57 PM
RE: LM6171 / LM6172 / LM7171 SPICE model - от nazar - 11-30-2018, 09:19 AM
RE: LM6171 / LM6172 / LM7171 SPICE model - от nazar - 05-06-2019, 12:54 PM
  TL071 / TL072 / TL074 SPICE model nazar 3 3,134 05-12-2024, 03:45 AM
  TP2581/TP2582/TP2584 SPICE model nazar 0 954 10-06-2023, 07:32 AM
  TPH2501 / TPH2502 / TPH2503 / TPH2504 SPICE model nazar 0 798 09-04-2023, 05:31 AM
  NE5532 SPICE model nazar 6 5,269 05-05-2023, 01:57 PM
  NE5534 SPICE model nazar 8 5,322 05-05-2023, 01:57 PM
