AD8055 / AD8056 SPICE model
The following parameters are modeled:
1. Open loop gain and phase with RL and CL effects
2. AC/DC Common mode rejection ratio
3. AC/DC Power supply rejection ratio
4. Slew rate
5. Input voltage noise with 1/f
6. Input curent noise with 1/f
7. Input bias current with common mode and temperature effects
8. Input offset current with temperature effects
9. Input offset voltage with temperature effects
10. Input impedance
11. Output current through the supply rails
12. Output current limit
13. Output voltage swing from rails with RL effects
14. Output impedance
15. Quiescent current vs Supply voltage with temperature effects
16. Maximum supply voltage breakdown
17. Overload recovery / No phase reversal
18. Input common mode voltage range
http://s-audio.systems/blog/spicemodels/
.zip AD8055bench.zip Размер: 9.19 KB  Загрузок: 41
The following 7 users say Thank You to nazar for this post:
  • mellowman (04-18-2017), EDWARD (04-20-2017), flipper (04-21-2017), BesPav (04-25-2017), naroznyv (05-11-2017), pvm (10-04-2017), Tuvalu (08-24-2018)
AD8055 / AD8056 SPICE model - от nazar - 04-18-2017, 02:52 PM
RE: AD8055 / AD8056 SPICE model - от mellowman - 04-18-2017, 03:23 PM
RE: AD8055 / AD8056 SPICE model - от nazar - 04-19-2017, 10:14 AM
RE: AD8055 / AD8056 SPICE model - от begemot - 04-19-2017, 10:43 AM
RE: AD8055 / AD8056 SPICE model - от nazar - 04-19-2017, 11:17 AM
RE: AD8055 / AD8056 SPICE model - от begemot - 04-19-2017, 02:11 PM
RE: AD8055 / AD8056 SPICE model - от nazar - 04-19-2017, 02:22 PM
RE: AD8055 / AD8056 SPICE model - от nazar - 04-20-2017, 04:10 PM
RE: AD8055 / AD8056 SPICE model - от nazar - 10-03-2017, 05:49 AM
RE: AD8055 / AD8056 SPICE model - от begemot - 10-03-2017, 09:27 AM
RE: AD8055 / AD8056 SPICE model - от nazar - 10-03-2017, 09:37 AM
RE: AD8055 / AD8056 SPICE model - от begemot - 10-03-2017, 10:09 AM
RE: AD8055 / AD8056 SPICE model - от nazar - 10-03-2017, 10:34 AM
RE: AD8055 / AD8056 SPICE model - от mellowman - 10-03-2017, 10:36 AM
RE: AD8055 / AD8056 SPICE model - от nazar - 10-03-2017, 10:38 AM
RE: AD8055 / AD8056 SPICE model - от begemot - 10-03-2017, 11:50 AM
RE: AD8055 / AD8056 SPICE model - от nazar - 10-03-2017, 12:12 PM
RE: AD8055 / AD8056 SPICE model - от nazar - 12-07-2018, 06:20 AM
RE: AD8055 / AD8056 SPICE model - от nazar - 12-12-2018, 11:56 AM
Последний пост от nazar
05-05-2023, 01:57 PM
