RC Cut-Off Frequency & Time Constant Calculator
If you are estimating stability of feedback system, determining bandwidth or decoupling components for your circuit, RC time constant or cut-off frequency is one of essential parameters. This calculator will help you to evaluate cut-off frequency and time constant of RC circuit.
Enter two out of three values; resistance, capacitance or frequency.
You can also enter two values out of resistance, capacitance or time constant.
Get the rest calculated.
You can use scientific notation to enter data (example: 1.25e-3; 529.46e5)
%e ( Ohm ) Resistor
     and
   %e ( F ) Capacitor
     will have
   %e ( S ) Time constant
     and
   %e ( Hz ) Cut-Off Frequency
$R_Value, $C_Value, $t_Value, $F_Value) ;
Comments
Comments are closed.
