THS4011 SPICE model
* The following parameters are modeled:
* 1. Open loop gain and phase with RL and CL effects
* 2. AC/DC Common mode rejection ratio
* 3. AC/DC Power supply rejection ratio
* 4. Slew rate
* 5. Input voltage noise with 1/f
* 6. Input curent noise with 1/f
* 7. Input bias current with common mode
* 8. Input offset current
* 9. Input offset voltage with temperature effects
* 10. Input impedance
* 11. Output current through the supply rails
* 12. Output current limit
* 13. Output voltage swing from rails with RL effects
* 14. Output impedance
* 15. Quiescent current vs Supply voltage with temperature effects
* 16. Maximum supply voltage breakdown
* 17. Overload recovery / No phase reversal
* 18. Input common mode voltage range
http://s-audio.systems/blog/spicemodels/
The following 6 users say Thank You to nazar for this post:
  • flipper (04-21-2017), BesPav (04-25-2017), naroznyv (05-11-2017), Tuvalu (08-24-2018), EDWARD (10-09-2018), Юрий_Uri (12-13-2018)
Поправил модель согласно измеренных данных
  TL071 / TL072 / TL074 SPICE model nazar 3 3,136 05-12-2024, 03:45 AM
  TP2581/TP2582/TP2584 SPICE model nazar 0 957 10-06-2023, 07:32 AM
  TPH2501 / TPH2502 / TPH2503 / TPH2504 SPICE model nazar 0 798 09-04-2023, 05:31 AM
  NE5532 SPICE model nazar 6 5,271 05-05-2023, 01:57 PM
  NE5534 SPICE model nazar 8 5,324 05-05-2023, 01:57 PM
